TM1 10.2.1 with IE 11 - Issues anyone?
spiderwallet
OLAP Product: Cognos
Version: 10.2.1
Post by spiderwallet »
Just a quick one to see if anyone has come across any issues with IE 11 when using TM1 10.2.1?
I have tested IE 11 with contributor, tm1web and operations console with minimal issues. According to the IBM website TM1 10.2.1 is only supporting IE up to version 10 but support Cognos BI up to IE 11 in compatibility mode :|
Thanks in advance!
SW
EvgenyT
Version: PAL 2.0.8
Re: TM1 10.2.1 with IE 11 - Issues anyone?
Post by EvgenyT »
Yes, we have had issues with Insight and IE 11.
Evgeny
TrevorGoss
Version: 10.2.1.1
Excel Version: 14.0.6129.5000
Post by TrevorGoss »
spiderwallet,
can you please, if possible, provide the link to the IBM website that told you about 10.2.1 only supprting IE up to version 10? Thanks
EvgenyT,
could you please provide more details about the problems IE 11 is giving you? Thanks
Our team is looking at IE11 and we will eventully upgrade to it, but we want to be very careful indeed, so the more information we can get the better.
I will post more when I find out more, as well as the testing we do with TM1 and IE11.
Thanks.
TrevorGoss wrote:spiderwallet,
All environment support information can be found below:
http://www-01.ibm.com/support/docview.w ... wg27043712
I was under the impression that it was only the initial 10.2 releases that didn't have IE11 support listed but I'm pretty sure the later releases do; in the event you were still using a near "base" install of 10.2 then you will have bigger issues than some browser discrepancies.
TrevorGoss
Version: 10.2.1.1
declanr, thanks for that. We will upgrade in due course, but we will approach IE with caution, even with the latest upgrade, simply because of the risks involved.
