Curious Question- Multiple Admin Servers
aostreicher
Version: 9.5- 10.2
Post by aostreicher »
Is it possible to run multiple admin servers from a single host server? I am distinctly referring to the admin server - not TM1 instances (which I am aware multiple instances can run from a single admin server).
I know this would require some redirecting of files and also different port numbers. Does anyone know specifically which files, etc.? Has anyone done this and could provide me some guidance? I would greatly appreciate any feedback in direct reference to either having attempted or done this. Thanks!
Re: Curious Question- Multiple Admin Servers
The problem is you would have to change the port that the Admin Host service uses to communicate with the TM1 Server services and that is not a configurable option. So, the answer is no AFAIK.
jim wood
Version: PA 2.0.7
Post by jim wood »
You cold always break the server up in to several virtual machines. I would say however that the only real benefit of this is to save money on tin which may be off set by memory upgrade costs anyway.
