Scorecarding with TM1
mce
Excel Version: 2013 2016
Post by mce »
As scorecarding feature is added to TM1 in version 10.2 in less than a year ago, I am wondering if there are any client references for the implementation and use of this feature in a live production environment.
I would appreciate if you can let me know of this in case you have any info.
jim wood
Version: PA 2.0.7
Re: Scorecarding with TM1
Post by jim wood »
I know that there are plenty of demos out there showing it off to potential customers. I doubt there are that many using it yet. A lot of previous TM1 users don't adopt major releases early based on previous issues. That coupled with the issues that 10.2 has, I doubt many will have started using it yet. May be we'll start to see some usage over the next year? I might be wrong. It would be interesting to hear others perspective on this.
George Regateiro
Version: 10.1.1
Excel Version: 2007 SP3
Post by George Regateiro »
We have been developing a project in it and hit some scale issues trying to use it against our biggest cube. It has potential but is very much a V1 pass of the product. If you have a targeted requirement like most of the demos you should be able to get it working well. If you have to step outside of their defined parameters you will hit some walls.
George Regateiro wrote:If you have to step outside of their defined parameters you will hit some walls.
And probably building it the way like we did before (rules to calculate trends, e.g.)
I did not set it up yet, just as I did almost nothing with Performance Modeler up to now. I'm not the only one I think ;-)
