In the Measure Dimension, I have the consolidations defined for three categories A, B and there are elements present in them. The Summation of different measures is happening at the Consolidation level which is not correct and I want to make it to zero. I have applied as below but it throws the error as element is ambigous. Any Ideas??
[{'A', 'B'} ] = C: 0;
Thanks in Advance
Force the Measure Elements at Consolidation
- Version: 10.2
Re: Force the Measure Elements at Consolidation
If you have an element named 'A' in more than one dimension in the same cube then the rules for that cube need to specify which dimension e.g.:
[{ 'dim1':'A', 'dim1':'B' }] = C: 0;
Robin Mackenzie
- Version: 10.2
Thanks a lot. It is working as expected if I define it separately for each element as below:
['dim1':'A'] = C: 0;
['dim1':'B'] = C: 0;
But when I define as [{ 'dim1':'A', 'dim1':'B' }] = C: 0; , it gives me error.
The exact syntax is different:
['dim1':{'A','B'}] = C: 0;
Thanks for the correction, Wim, I was doing it totally off the top of my head.
Robin Mackenzie
No problem Robin, you're welcome.
