Converting Planning Built-in Function into TM1 Rules
- Version: v10.1
- Excel Version: Excel 2010
Hi, I am a beginner in TM1, I have a task to convert Planning Built-in functions into TM1 rules, Those built-in functions are @Last, @LeaseVariable, @Cumul, @lag, @Feed.
Re: Converting Planning Built-in Function into TM1 Rules
You are also a beginner in this forum as well. Suggest you read the request for assistance guidelines. That being said, you don't have a snowball's chance in hades of accomplishing your goal. Most of those functions are quite complex and way over the head of many people on this forum, much less a beginner. Why anyone would expect a complete novice to be able to do something like that is beyond me.Zanele wrote:Hi, I am a beginner in TM1
- jim wood
- Version: PA 2.0.7
Some of this covered in the 10.1 developer training course that you can get from one of IBM's training partners. I would recommend the introduction to TM1 then the developer course. Tomok is right, this is no simple stuff that you're trying to achieve. Without this training as foundation you're going to be climbing a very steep hill,Zanele wrote:Hi, I am a beginner in TM1, I have a task to convert Planning Built-in functions into TM1 rules, Those built-in functions are @Last, @LeaseVariable, @Cumul, @lag, @Feed.
And... falling off many times.jim wood wrote:Without this training as foundation you're going to be climbing a very steep hill,
The company pays less in the short run, but forgets that in the middle to long run, they pay lots and lots more.tomok wrote:Why anyone would expect a complete novice to be able to do something like that is beyond me.
- Version: 9.5.2 to 10.2
- Excel Version: 2007 - 2013
Well said Wim!!!!The company pays less in the short run, but forgets that in the middle to long run, they pay lots and lots more
It amazes me how organizations will choose the less experienced and cheaper resource in order to assumedly save a few bucks
In the end they spend much more time and money while their resource learns on their dime
Certainly everyone has to start somewhere but this is not an effective method that unfortunately seems to be the norm these days
Best,
Solanna
@Last
I would recommend using a TI function that does a while loop back from that period until it finds a value. You can do this by a rule also but it would be inefficient and cumbersome if you have a large time dimension.
@LeaseVariable
Annuity calculations etc have been discussed a few times on this forum so searching may help you but I wouldn't recommend starting with such a calculation while you are still learning. That being said however, as long as you understand the maths and/or have a grounding in accounting it will be reasonably straightforward to set up once you get to grips with TM1s calculation engine.
@Cumul
With TM1 the usual method for this is to just use consolidations (e.g. YTD and/or CUM) but its easy enough to set up with a rule as well, in a rule just make sure to add the prior periods YTD calc'd value to this period's "in date" value.
@Lag
Simple rule referencing "Prior" attributes (sometimes nested 2 Prior etc), just make sure to also have a "next" attribute for the feeder portion of the rule.
@Feed
Again you have "Closing" as a simple consolidation of "Opening", "In", "Out" etc. then you have "Opening" set up as a rule looking at the "Prior" period's "Closing" (remember to through in the feeder.)
You will note that most of the above need common attributes set up, there are a lot of things it helps to set up before you start in such generic terms, most of us have historically done this as standard practice but nowadays I believe PM creates such attributes "out of the box" for you and I would assume as an EP user you have been "sold" TM1 on the basis of using PM. All the above are basic examples to give you an idea, none are definitive - you will find that with TM1 there are multiple ways of doing anything and which is best for you will depend entirely on your specific situation and a bit of trial and error will probably help you get there.
@LeaseVariable
@Cumul
@Lag
@Feed
- Version: v10.1
Hi Declan
Thanks for your input. I managed to resolve @Feed and @Cumul. I am still busy with the other functions.
I'm glad you're not doing it on my dime.Zanele wrote:Hi Declan
