hi everyone,
I can not find anywhere how to wrap the text in cube,
for example:
I have a string element - "comments", in formula writing the condition and the result should be one or the other comment, but the comment is written in a single line, which is very inconvenient, because it increases the width of the column.
Maybe someone will tell me how to make that text wraps from line to line
Thank you.
Wrap text in Cognos TM1
Re: Wrap text in Cognos TM1
TM1 Web has a web.config parameter for the character width to wrap text. This applies to web cube viewer and Contributor interfaces. (not sure if this parameter also exists in the new 10.2 java web but I would hope so).
However the thick client cube viewer has no such ability to wrap text. If the text is too long for the column you just don't see it all. Nothing to be done but raise a new feature request.
