TM1 Operations Console: None of the servers are contactible
I am running TM1 10.1 on Windows. I tried to start tm1 operations console. When I choose adminhost and move to the servername, a message 'None of the servers are contactible" appears, despite the fact that I have added certificates to JRE keystore
I have tried restarting the tomcat server, restarting application server from cognos configuration and changing opsconfig.xml, once adding that certificates
Any other thing that I miss?
Andre
Andre
- Steve Vincent
- Version: 10.2.2 FP1
Re: TM1 Operations Console: None of the servers are contacti
i commented on an issue in this thread a while ago - are there client min/max settings in your server config?
- Version: 2.0.5
Do you have a JAVA_HOME variable set in your environment variables? If you do, is it set to the JRE that was installed with TM1 10.1? Had this problem on a DEV box where another software had setup the JAVA_HOME variable to it's own JRE and when I added the certificates to the cognos JRE it gave me this error. You would either have to change JAVA_HOME or hack the tomcat startup to hardoce the JRE location.
I do not have client min/max settings in the tm1 configuration file. I do not have JAVA_HOME environment variable either.
I tried to re-add the certificates but got a message: certificates not imported, alias <mykey> already exists. I think the certificates has been successfully added before when I ran "keytool -import -file ... -keystore ... -storepass "changeit" as per TM1 documentation", but somehow the ops console still does not work
If I want to remove the certificates and re-add, what command should i use? I come accross a command keytool -delete -alias mydomain -keystore keystore.jks. In that case, what alias that I should use?
thanks
thanks
- Steve Vincent
Never tried to remove a key so i'm not really sure. Are you able to install 10.1 server and client on a single machine and test it that way? Assuming you have done all the other stuff like adding a user / group and defining that in the web config as per the instructions then i'm not sure what else it could be. Sounds like it might be worth raising with IBM.
- Version: 2.5 to PA
- Excel Version: Lots
To use the -delete option, just use the same method that you used for -import, but miss out the -file section
keytool -delete -keystore "C:\Program Files\ibm\cognos\TM1_64\bin64\jre\6.0\lib\security\cacerts" -storepass "changeit"
Andy Key
- Version: 9.5.1
- Excel Version: 2003 2007
Are you using a 64-bit version of TM1 on a 64-bit version of Windows ?
If so, did you to add the certificates to the bin64 folder as outlined by the IBM Technote 1585781 ?
http://www-304.ibm.com/support/docview. ... wg21585781
TM1 10 Operation Console: None of the servers are contactible
I have tried deleting the certificate and re-added it but the server is still not contactable.
I use 32 bit TM1 on 32 bit Windows Vista Business SP1. I also use the TM1 installation provided Apache Tomcat.
Andre
Andre
I managed to install it successfully. I think the error was because I did not run the command prompt as an administrator when adding JRE certificate
Andre
Andre
- OLAP Product: cognos tm1
- Version: 10.1.1
I am not able to add the certificates in jre keystore.
The command, I am executing in cmd prompt is:-
Keytool -import -file
“C:\Program Files\ibm\cognos\tm1\bin\ssl\applixca.pem”
-keystore
“C:\Program Files\ibm\cognos\tm1\bin\jre\6.0\lib\security\cacerts”
-storepass “changeit”
The error , I am getting is:-
'Keytool' is NOT recognized as an internal or external command.
Roy.
-keystore
Roy.
- OLAP Product: IBM
- Version: 10.1
- Excel Version: 2013
Hi Roy,
I had the same issue but fixed this by "CD"ing to the folder the keytool is in.
Hope that helps
Mike
Hope that helps
Mike
