It's Express 10.1 question,
There's a Cognos package created with Framework Manager from a TM1 cube. Reports from this package are built with Report Studio. When I run a report on the server logged in with my AD id the system prompts for login. When I enter here the systemadmin id in CognosExpress namespace the report runs ok.
When a report is run on a workstation with AD login there's a SAX error generated, below a couple of lines from cogserver.log:
.......Failure CST-AOM-0016 A SAX error with the message 'Expected end of tag 'SOAP-ENV:Envelope'' occurred while processing the request. CST-AOM-0016 A SAX error with the message 'Expected end of tag 'SOAP-ENV:Envelope'' occurred while processing the request.
.......Audit.RTUsage.RSVP Response Report ReportService Failure RSV-SRV-0066 A soap fault has been returned.
I've checked in Cognos Connection:
- package permissions
- report permissions
- CXMD data source permissions in Cognos Administration
& cube access rights in Architect
What could be missing since it's not run with AD id? What would be required in Express Manager data source definitions if anything since it's a FM package anyway?
