Hi,all
I just tested out It may be a bug that TI run with "Base" data in TM1 10.2 even if a private sandbox is created and actived.
The same server present different behavior between TM1 10.1.1 FP2 and TM1 10.2.
TM1 10.1.1:
TI always run with active sandbox without any setting. All source and result are in active sandbox for each non-admin Client.
TM1 10.2
TI always run with "Base" Sandbox unless "Right Click on Process - Use Active Sandbox " is selected.
Every Client has to click that in each TI... that does'nt make any sense.
Or is there any new setting in tm1s.cfg ( I have checked the offical document and found nothing >< )?
Any one faced this situration before?
Is it a bug with Sandbox and TI in TM1 10.2?
- paulsimon
- Version: PA 2.0.5
Re: Is it a bug with Sandbox and TI in TM1 10.2?
Have you looked at the settings for user capabilities. Those can govern whether a user has writes to sandboxes
solverxyz
- OLAP Product: NONE
- Version: TM1 9.5.2
- Excel Version: 2003
I Have already checked, all client have full write to sandbox.
The server is started with the same folder and data and even the same tm1s.cfg.
Only the TM1 version is different.....><
Thanks anyway
Thanks anyway
