Hello all,
I have been searching for the TM1 Message Log when using Performance Modeler 10.2. I simply cannot find it.
When we execute a process with errors, we can see a similar screen compared to Architect/Perspectives.
But when process A executes process B and B gives errors, we cannot navigate to the erros of that process B. At least, I can't.
Can anybody help me please?
Thanks !
TM1 Message Log in Performance Modeler
roy2087
- OLAP Product: cognos tm1
- Version: 10.1.1
Re: TM1 Message Log in Performance Modeler
You can try out this Path in your system:
C:\Users\<username>\AppData\Roaming\IBM\Cognos Performance Modeler
Note:
1.You will get to see the log , only if you get an error in your Performance Modeler
2.AppData is will be a hidden folder, you need to "Unhide" it.
Roy.
Note:
Roy.
Hello Roy
Thank you for your post, but I meant the tm1server.log file that is stored in the TM1 logging directory.
How can we navigate this log file in the Performance Modeler environment?
Thanks.
Thanks.
