Deleting history in TM1 Cube
vins
Post by vins »
Hi experts,
Kindly let me know how to delete history of records in TM1 Cube using TI process?
Re: Deleting history in TM1 Cube
You will need the
ViewZeroOut
function, applied to a view on a cube. Use the
ViewCreate
function, and a bunch of other functions.
Most probably, the view creation has been scripted in the same process, but that's not needed.
It could even be a view that you save manually in the cube viewer (it's also possible to clear the data manually in the cube viewer).
EvgenyT
Version: PAL 2.0.8
Post by EvgenyT »
Simple example along these lines:
# Create View
sView = cTI|NumberToString(Rand*Rand);
IF( ViewExists( cubDestination, sView ) = 1 );
ViewDestroy( cubDestination, sView );
ENDIF;
ViewCreate( cubDestination, sView );
ViewZeroOut( cubDestination, sView );
Obviously you will have to create subsets for dimension with elements you want to clear e.g. Jun 2013 Budget data..
Check out this link with all Subset function:
http://pic.dhe.ibm.com/infocenter/ctm1/v9r5m0/index.jsp
Try to write a simple ZeroOut process and when you get stuck let us now.
ET
vins
Post by vins »
@EvgenyT : Thanks a ton.. I was able to achieve my requirement.
EvgenyT
Version: PAL 2.0.8
Post by EvgenyT »
You are welcome ;)
