Sorry for so many questions in my last post
If there are 4 Branch Managers and all have access to one cubes in TM1 application.But I want to know whether only one BM can update the cube values or all can update the values at the same time in a cube in the application.Please suggest how we can achieve this?
Access issue in TM1 application
Darkhorse
- Excel Version: 2003 2007 2010 2013
Re: Access issue in TM1 application
create a test usr with the same access rights and test yourself
If you talk about updating the exact same cube slice at the the same time, it's "first come, first served". The first one in can update the cube value, the other one(s) will wait, and when they can write to the cube, they could in fact overwrite the earlier entry of BM number 1.dilip wrote:But I want to know whether only one BM can update the cube values or all can update the values at the same time in a cube in the application.
In different slices of the same cube, they can update the cube values.
The above, of course, under the assumption of write access to the cube.
dilip
- Version: 9.4
Thank you Wim.
