On our test server (we are using TM1 10.1 in test), when i open the TM1 architect, it shows as a running process in the background, but i cannot see it on the screen. However, when my counterpart opens it up when she logs in, it opens just fine. We both have the same ADMIN rights on the server. Anyone have any suggestions or thoughts as to what is happening?
Here is the process that is running in the background "tm1a.exe*32"
Thank you in advance!
TM1 Architect
nmiller
- Version: 9.4
Re: TM1 Architect
Yes we were able to see it but i found the solution. I did a search on the server under my username for the tm1p.ini file and realized there were more than 1 file (got this from the IBM site). I had to change the "AdminHost" to reflect the servername. Once i did this, all is well. Here is a link to the instructions:bplaia wrote:Can you see Architect on the Windows taskbar?
http://www-01.ibm.com/support/docview.w ... wg21473097
