Using TM1 Version 9.5.2, FP2.
I would like to write a TI Process to update an existing dimension, for existing N-level dimension elements, and change them into Consolidations (Update the element DTYPE from N to C).
I know in the dimension editor, I can manually update the element Properties / Element Type from Simple to Consolidated.
Is there any way to do this in a TI Process?
Can a TI change a dimension element Type from N to C?
Re: Can a TI change a dimension element Type from N to C?
All you have to do is add a child to the element. The conversion happens automatically. Personally I find that to be a bit dangerous, but there are others who find it a useful feature.jcr55 wrote:Using TM1 Version 9.5.2, FP2.
jcr55
- Version: 9.5.2 FP2
- Excel Version: Excel 2007
Thank you for the quick response...
That is what I thought, that the DimensionElementComponentAdd function would change the target parent into a Consolidated element if needed.
My initial test of that did not create the parent/child relationship, and the target parent element remains an N-level element. However, I tried to create the new 'child' element in Metadata and then update the hierarchy in the Data tab of the same TI Process. I am guessing the newly created N-level elements somehow can't be used to assign to a parent within the same TI process.
I will split those actions into separate TI processes.
There's your problem, metadata changes are not valid when done in the Data tab of a TI process. Move your hierarchy maintenance code to the metadata tab and it will work.jcr55 wrote:My initial test of that did not create the parent/child relationship, and the target parent element remains an N-level element. However, I tried to create the new 'child' element in Metadata and then update the hierarchy in the Data tab of the same TI Process.
