I have defined picklists (numeric output static:1,1343:1,08) for two elements in a dimension. The problem i am facing is that , the comma (for example between 1 and 1343) don´t delivered. What is the problem?
Thank you in anticipation!
Pick List
Re: Pick List
Can't say I have played much with picklists and decimal places but I wonder if its to do with the fact that although you are formatting your numbers with the euro styleAuvi wrote:I have defined picklists (numeric output static:1,1343:1,08) for two elements in a dimension. The problem i am facing is that , the comma (for example between 1 and 1343) don´t delivered. What is the problem?
static:1.1343:1.08
- Version: 9.5.2
- Excel Version: Office 2010
Re: Pick List
Wow, thank you for your fast and right answer.
