URL API
Ivan Cepero
URL API
Post by Ivan Cepero »
I'm having trouble using the URL API. I want to open a cubeview and set the title elements. I can set all title elements except the cost center dimension.
Here's the URL I am using:
http://localhost/TM1web/TM1webmain.aspx?action=OpenObject&type=CubeViewer&value=tn_5&title_Entity=10 - US&title_Version=CurrentForecast&title_cost center=1010 - Manufacturing - Instruments&title_Account=7600-6046 - Meals
The only difference that I can see is that the cost center dimension name has a space in it. I have tried using title_cost%20center= but that doesn't work either.
Does anyone know what's wrong with the URL?
Martin Ryan
Re: URL API
Post by Martin Ryan »
Ivan Cepero wrote:&title_cost center=1010 - Manufacturing - Instruments
Try making it "title_cost_center". Variables can have spaces, but I don't think the variable names can.
Martin
Jodi Ryan Family Lawyer
rmackenzie
Re: URL API
Post by rmackenzie »
http://localhost/TM1web/TM1webmain.aspx ... _Entity=10 - US&title_Version=CurrentForecast&title_cost center=1010 - Manufacturing - Instruments&title_Account=7600-6046 - Meals
Try this - replacing any space in the URL with %20
http://localhost/TM1web/TM1webmain.aspx?action=OpenObject&type=CubeViewer&value=tn_5&title_Entity=10%20-%20US&title_Version=CurrentForecast&title_cost center=1010%20-%20Manufacturing%20-%20Instruments&title_Account=7600-6046%20-%20Meals
Robin Mackenzie
Ivan Cepero
Re: URL API
I tried title_cost_center and replacing every space with a $20. I even built another test cube with a costcentertest dimension. I can't set that title dimension. Weird.
Kyro
OLAP Product: MODLR - The CPM Cloud
Version: Always the latest.
Excel Version: 365
Re: URL API
Post by Kyro »
Probably a typo but try %20 instead.
Also since your view is possibly saved using aliases (and even it its not) possibly use the elements principal name, the view should present the alias name still if thats how the view was constructed.
so instead of :
try:
http://localhost/TM1web/TM1webmain.aspx?action=OpenObject&type=CubeViewer&value=tn_5&title_Entity=10&title_Version=CurrentForecast&title_cost%20center=1010&title_Account=7600-6046
I am just guessing at your element principal names though. I've had a lot of trouble getting URL API working and so I sympathize.
Edit 1: just another thought perhaps also replace '-' with its POST HTML code: '%2D'
Edit 2: wow, just saw the date on your post. sorry. my response is a little expired.
