I am trying to think of an MDX that would give me all the top level elements of a dimension. I saw this discussion http://www.tm1forum.com/viewtopic.php?p=26127 which came to no real conclusion as to my problem. What I have in mind is the following:
{Head ( TM1SubsetAll ( [Clients] ) )} gives me the first top level element, the name of it is "All Client Groups".
{[Clients].[All Client Groups].Siblings} gives me all the elements which I want to see (i.e. all the top level elements and, yes, there are N-elements among them which is okay for me).
Now I tried something like this, but I failed: {[Clients].[{Head ( TM1SubsetAll ( [Clients] ) )}].Siblings}
To be precise: In my mind, top level elements are elements that have no parent. If someone can give me a solution for "Consolidated elements that have no parent" that would be fine as well in this case.
Holger
MDX to select top level elements
- Michel Zijlema
- OLAP Product: TM1, PALO
Re: MDX to select top level elements
Maybe this is what you're looking for?:
Michel
EDIT: although I see that one is covered in the thread you referred to
{FILTER( {TM1SUBSETALL( [Clients] )}, [Clients].CurrentMember.Parent.Name="")}
- Version: 9.4 9.5.1
- Excel Version: 2003 - 2007
Hi holger,
this should work:
{ FILTER(
{TM1SUBSETALL( [MyDim] )},
[MyDim].CurrentMember.Level.ordinal = 0
level.ordinal refer to generation starting by 0.
this should work:
{ FILTER(
Statements like that can be found on this page (direct link to my website):
http://users.skynet.be/fa436118/wim/tm1 ... nts_EN.htm
Perfect! Thanks to all of you for your quick help.
Best regards
Holger
Best regards
Holger
