We moved our tm1 server to new machine. And got headache of spontaneous restart of TM1 server. Has anybody any ideas?
TM1 cfg
GroupsCreationLimit=100
[TM1S]
AllowSeparateNandCRules=T
ReevaluateConditionalFeeders=T
ServerLogging=F
SecurityPackageName=Kerberos
IntegratedSecurityMode=5
UseSSL=F
ServerName=Budget
DataBaseDirectory=D:\TM1Data\Budget\DATA
LoggingDirectory=D:\TM1Data\Budget\LOGS
AdminHost=localhost
PortNumber=10000
Language=ENG
SaveTime=
DownTime=
ProgressMessage=True
AuditLogOn=F
AuditLogMaxFileSize= 50 MB
AuditLogUpdateInterval=60
PersistentFeeders=F
ParallelInteraction=T
ServerCAMURI=http://********************************************************************************
ClientCAMURI=https://********************************************************************************
ClientPingCAMPassport=110
CAMPortalVariableFile = portal\variables_TM1.xml
#IdleConnectionTimeOutSeconds=7200
DefaultMeasureDimension=T
#Optional CAM parameters
#CAMSSLCertificate=
#CAMSSLCertRevList=
#SkipSSLCAMHostCheck=TRUE
[color=#888888]8600 [327] INFO 2012-11-16 08:43:45.124 TM1.Process Process "}tp_get_user_permissions" run from process "}tp_workflow_enter_node" by user "CAMID("AD:u:17f7d592546878429a462a9402094396")"
8600 [327] INFO 2012-11-16 08:43:45.124 TM1.Process Process "}tp_get_log_file_names" run from process "}tp_get_user_permissions" by user "CAMID("AD:u:17f7d592546878429a462a9402094396")"
8600 [327] INFO 2012-11-16 08:43:45.140 TM1.Process Процесс "}tp_get_log_file_names": - выполнение завершено нормально, истекшее время: 0.02 сек.
8600 [327] INFO 2012-11-16 08:43:45.140 TM1.Process Процесс "}tp_get_user_permissions": - выполнение завершено нормально, истекшее время: 0.02 сек.
8600 [327] INFO 2012-11-16 08:43:45.155 TM1.Process Процесс "}tp_workflow_enter_node": - выполнение завершено нормально, истекшее время: 0.05 сек.
5932 [6ac] INFO 2012-11-16 08:43:45.389 TM1.Process Process "}tp_initialize_session" executed by user "RTRS/Саваренко Марианна Петровна"
5932 [6ac] INFO 2012-11-16 08:43:45.405 TM1.Process Процесс "}tp_initialize_session": - выполнение завершено нормально, истекшее время: 0.02 сек.
9952 [68f] ERROR 2012-11-16 08:43:52.191 TM1.Blob CommitDeferredFileCommand - Create failed: err=5 system_err_code=123
9952 [68f] ERROR 2012-11-16 08:43:52.191 TM1.Blob Commit - file operation failure for blob: Budget-F_01_Append.Приложение ПД к БДиР_cc251517-7403-4b44-b8e6-a2584b7a9342_[ЦФО - Бюджет].[927].CAMID("AD:u:3a6b56d10e11cb458f8033e0f7b3adee")
5528 [68b] INFO 2012-11-16 08:43:53.330 TM1.Process Process "}tp_workflow_leave_node" executed by user "RTRS/Волкова Мария Юрьевна"
5528 [68b] INFO 2012-11-16 08:43:53.330 TM1.Process Process "}tp_get_log_file_names" run from process "}tp_workflow_leave_node" by user "CAMID("AD:u:3a6b56d10e11cb458f8033e0f7b3adee")"
5528 [68b] INFO 2012-11-16 08:43:53.330 TM1.Process Процесс "}tp_get_log_file_names": - выполнение завершено нормально, истекшее время: 0.00 сек.
5528 [68b] INFO 2012-11-16 08:43:53.330 TM1.Process Process "}tp_get_application_attributes" run from process "}tp_workflow_leave_node" by user "CAMID("AD:u:3a6b56d10e11cb458f8033e0f7b3adee")"
5528 [68b] INFO 2012-11-16 08:43:53.330 TM1.Process Процесс "}tp_get_application_attributes": - выполнение завершено нормально, истекшее время: 0.00 сек.
5528 [68b] INFO 2012-11-16 08:43:53.330 TM1.Process Process "}tp_get_user_permissions" run from process "}tp_workflow_leave_node" by user "CAMID("AD:u:3a6b56d10e11cb458f8033e0f7b3adee")"
5528 [68b] INFO 2012-11-16 08:43:53.346 TM1.Process Process "}tp_get_log_file_names" run from process "}tp_get_user_permissions" by user "CAMID("AD:u:3a6b56d10e11cb458f8033e0f7b3adee")"
5528 [68b] INFO 2012-11-16 08:43:53.346 TM1.Process Процесс "}tp_get_log_file_names": - выполнение завершено нормально, истекшее время: 0.00 сек.
5528 [68b] INFO 2012-11-16 08:43:53.361 TM1.Process Процесс "}tp_get_user_permissions": - выполнение завершено нормально, истекшее время: 0.02 сек.
5528 [68b] INFO 2012-11-16 08:43:53.361 TM1.Process Процесс "}tp_workflow_leave_node": - выполнение завершено нормально, истекшее время: 0.03 сек.
5932 [6ac] INFO 2012-11-16 08:43:53.876 TM1.Process Process "}tp_workflow_enter_node" executed by user "RTRS/Саваренко Марианна Петровна"
5932 [6ac] INFO 2012-11-16 08:43:53.876 TM1.Process Process "}tp_get_log_file_names" run from process "}tp_workflow_enter_node" by user "CAMID("AD:u:a2e5e4b2389f5842a8b07cdf66301021")"
5932 [6ac] INFO 2012-11-16 08:43:53.876 TM1.Process Процесс "}tp_get_log_file_names": - выполнение завершено нормально, истекшее время: 0.00 сек.
5932 [6ac] INFO 2012-11-16 08:43:53.876 TM1.Process Process "}tp_get_application_attributes" run from process "}tp_workflow_enter_node" by user "CAMID("AD:u:a2e5e4b2389f5842a8b07cdf66301021")"
5932 [6ac] INFO 2012-11-16 08:43:53.876 TM1.Process Процесс "}tp_get_application_attributes": - выполнение завершено нормально, истекшее время: 0.00 сек.
5932 [6ac] INFO 2012-11-16 08:43:53.876 TM1.Process Process "}tp_get_user_permissions" run from process "}tp_workflow_enter_node" by user "CAMID("AD:u:a2e5e4b2389f5842a8b07cdf66301021")"
5932 [6ac] INFO 2012-11-16 08:43:53.892 TM1.Process Process "}tp_get_log_file_names" run from process "}tp_get_user_permissions" by user "CAMID("AD:u:a2e5e4b2389f5842a8b07cdf66301021")"
5932 [6ac] INFO 2012-11-16 08:43:53.892 TM1.Process Процесс "}tp_get_log_file_names": - выполнение завершено нормально, истекшее время: 0.00 сек.
5932 [6ac] INFO 2012-11-16 08:43:53.907 TM1.Process Процесс "}tp_get_user_permissions": - выполнение завершено нормально, истекшее время: 0.02 сек.
5932 [6ac] INFO 2012-11-16 08:43:53.907 TM1.Process Process "}tp_get_user_permissions" run from process "}tp_workflow_enter_node" by user "CAMID("AD:u:a2e5e4b2389f5842a8b07cdf66301021")"
5932 [6ac] INFO 2012-11-16 08:43:53.907 TM1.Process Process "}tp_get_log_file_names" run from process "}tp_get_user_permissions" by user "CAMID("AD:u:a2e5e4b2389f5842a8b07cdf66301021")"
5932 [6ac] INFO 2012-11-16 08:43:53.923 TM1.Process Процесс "}tp_get_log_file_names": - выполнение завершено нормально, истекшее время: 0.00 сек.
5932 [6ac] INFO 2012-11-16 08:43:53.938 TM1.Process Процесс "}tp_get_user_permissions": - выполнение завершено нормально, истекшее время: 0.03 сек.
5932 [6ac] INFO 2012-11-16 08:43:53.938 TM1.Process Процесс "}tp_workflow_enter_node": - выполнение завершено нормально, истекшее время: 0.06 сек.
7024 [2ca] ERROR 2012-11-16 08:43:58.962 TM1.Blob CommitDeferredFileCommand - Create failed: err=5 system_err_code=123
7024 [2ca] ERROR 2012-11-16 08:43:58.962 TM1.Blob Commit - file operation failure for blob: Budget-FOT.Фонд оплаты труда_cc251517-7403-4b44-b8e6-a2584b7a9342_[ЦФО - Бюджет].[083].CAMID("AD:u:01db827ebf63c742811305686c4f3145")[/color]
724 [] INFO 2012-11-16 08:45:23.781 TM1.Server Data Directory: d:\tm1data\budget\data
724 [] INFO 2012-11-16 08:45:23.781 TM1.Server Admin Host: cpm-tm1
724 [] INFO 2012-11-16 08:45:23.781 TM1.Server Logging Directory: d:\tm1data\budget\logs
724 [] INFO 2012-11-16 08:45:23.781 TM1.Server Configuration Directory: d:\tm1data\budget\
724 [] INFO 2012-11-16 08:45:23.781 TM1.Server Raw Store Directory: d:\tm1data\budget\data
724 [] INFO 2012-11-16 08:45:23.781 TM1.Server Port: 10000
724 [] INFO 2012-11-16 08:45:23.781 TM1.Server Client Message Port: Dynamic
724 [] INFO 2012-11-16 08:45:23.781 TM1.Server Client Message Port does not accept Tm1Top connections.
724 [] INFO 2012-11-16 08:45:23.781 TM1.Server Export Admin Server Certificate: 0
724 [] INFO 2012-11-16 08:45:23.781 TM1.Server Admin Server Certificate Authority: C:\Cognos\TM1_x64\bin\ssl\applixca.pem
724 [] INFO 2012-11-16 08:45:23.781 TM1.Server Admin Server SSL Cert ID: tm1adminserver
724 [] INFO 2012-11-16 08:45:23.781 TM1.Server Admin Server SSL Cert ID: tm1adminserverSSL Mode:
724 [] INFO 2012-11-16 08:45:23.781 TM1.Server Security Mode:
724 [] INFO 2012-11-16 08:45:23.781 TM1.Server Server CAM URI: http://***************************************************************************************
724 [] INFO 2012-11-16 08:45:23.781 TM1.Server Client CAM URI: https://***************************************************************************************
724 [] INFO 2012-11-16 08:45:23.781 TM1.Server Web CAM URI: https://***************************************************************************************
724 [] INFO 2012-11-16 08:45:23.781 TM1.Server Client Ping CAM Passport:
724 [] INFO 2012-11-16 08:45:23.781 TM1.Server Start time: Fri Nov 16 2012 12:45:23 PM
724 [] INFO 2012-11-16 08:45:23.781 TM1.Server The server will use Parallel Interaction.
724 [] INFO 2012-11-16 08:45:23.781 TM1.Server Режим потоков сервера - один поток на соединение.
724 [] INFO 2012-11-16 08:45:23.781 TM1.Server Порт сообщений клиента не принимает соединения Tm1Top.
5640 [] INFO 2012-11-16 08:45:23.781 TM1.Server Dynamic Client Message Port: 60561
5436 [] INFO 2012-11-16 08:45:23.781 TM1.Server --------------------Session Start--------------------
5436 [] INFO 2012-11-16 08:45:23.781 TM1.Server TM1 Build Number: 9.5.20200.22178
5436 [] INFO 2012-11-16 08:45:24.124 TM1.Cube Завершена загрузка куба Admin_Security_Версии
5436 [] INFO 2012-11-16 08:45:24.124 TM1.Cube Завершена загрузка куба Admin_Security_Этап согласования мероприятий
5436 [] INFO 2012-11-16 08:45:24.124 TM1.Cube Завершена загрузка куба Budget-Amort
5436 [] INFO 2012-11-16 08:45:24.124 TM1.Cube Завершена загрузка куба Budget-DDS_Do_Vzaimorascheta
5436 [] INFO 2012-11-16 08:45:24.124 TM1.Cube Завершена загрузка куба Budget-DDS_Do_Vzaimorascheta_Kv
5436 [] INFO 2012-11-16 08:45:24.124 TM1.Cube Завершена загрузка куба Budget-DDS_Grafik_Platezhei-Kv
5436 [] INFO 2012-11-16 08:45:24.124 TM1.Cube Завершена загрузка куба Budget-DDS_Grafik_Platezhei_Corr-Kv
5436 [] INFO 2012-11-16 08:45:24.124 TM1.Cube Завершена загрузка куба Budget-DDS_Grafik_Platezhei_Dohodi-Kv
5436 [] INFO 2012-11-16 08:45:24.124 TM1.Cube Завершена загрузка куба Budget-DDS_KZ_DZ_po_KV
5436 [] INFO 2012-11-16 08:45:24.124 TM1.Cube Завершена загрузка куба Budget-DDS_nereal_deb
5436 [] INFO 2012-11-16 08:45:24.124 TM1.Cube Завершена загрузка куба Budget-DDS_Posle_Vzaimorascheta-Kv
5436 [] INFO 2012-11-16 08:45:24.139 TM1.Cube Завершена загрузка куба Budget-DDS_Rasch
