Width of Columns in Contributor
EP_explorer
OLAP Product: PAL
Version: 2.0.9
Post by EP_explorer »
Is it possible to manage of width of columns in cube in COntributor (version 10.1)?
When I create an apllication which contains a cube where users have to input data - width of columns in the cube are so narrow and it is very incovenient to input data (string for example). Can I put a parameter somewhere to set a minimum width of columns.
rkaif
OLAP Product: IBM Cognos TM1
Version: 9.1 or later
Excel Version: 2003 or later
Re: Width of Columns in Contributor
Post by rkaif »
I havent tested it in 10.1 but there is a setting in the web.config file which allows you to set the column width
Look for the following in the web.config file:
<add key="CubeviewerStringWrap" value="Enabled=true;MinCharactersToWrap=20;MaxDisplayCharacters=200;WidthOfWrapCell=50" />
Cheers!
Rizwan Kaif
EP_explorer
OLAP Product: PAL
Version: 2.0.9
No it doesn't do that I want. It is simply put features of showing strings which had already inputted.
But if you load an empty cube you see very narrow columns and it is very inconvenient to input strings - it is shifting to the second row after 1 or 2 letters.
