hi,
I am not able to login to cam connection using TM1 api function TM1SystemServerConnect. ~It appears that this function only works for standalone TM1 security. We have cam authentication enabled with cognos 8 security. Does anyone know if there's any function for cam connection?
kind regards
Pradeep
TM1 API VBA function to establish cam connection
- Version: 9.4
- Excel Version: EXCEL 2003
- Mike Cowie
- OLAP Product: IBM TM1/PA, SSAS, and more
- Version: Anything thru 11.x
- Excel Version: 2003 - Office 365
Re: TM1 API VBA function to establish cam connection
Hi:
Have a look here:
http://www.tm1forum.com/viewtopic.php?f=3&t=3392
http://www-01.ibm.com/support/docview.w ... wg21418355
Should have what you need, and here are some notes I grabbed from an old post:
NOTE: there are some behavioral differences that you should be aware of with this CAMNamespace login method, as compared to native TM1 API login methods:
80: SystemServerClientNotFound
It could mean one of the following problems:
Mike
Have a look here:
- THE NAMESPACE PARAMETER IS CASE-SENSITIVE. For example, "CognosExpress" would be valid, but "Cognosexpress" would NOT be valid. User ID and Password are NOT case-sensitive.
- Failed login error messages returned by the TM1 API are incredibly unhelpful when making a CAM Namespace login. If the login attempt fails, for whatever reason, you will almost definitely see this error message: "80: SystemServerClientNotFound"
- You entered in the wrong namespace name, or didn't use the proper case for the namespace.
- Your user ID does not exist.
- Your password is incorrect.
Mike
Mike Cowie
QueBIT Consulting, LLC
- Version: 9.4
Thanks a Lot Mike, this is working fine now.
this wasnt in the documentation
