HI All,
Tm1 is running under one server and i am working with client in my local PC and
i feel i want to stop the TM1 server from my local machine SO to do this
what command's can we use to stop them ? or this kind of logic's can we impletement it?
Please advice.?
To stop TM1 server from my local machine
mincharug.shulft
Duncan P
- Version: 9.5.2 10.1 10.2
- Excel Version: 2003 2007
Re: To stop TM1 server from my local machine
Have a look at the AT command in Windows or the SCHTASKS.EXE which appears to be more flexible. Both of these set up a scheduled task but can do it on a remote computer. You could set up a task to run NET STOP command on the TM1 service perhaps.
[EDIT] Alternatively take a look at this, from the creator of Microsoft's SysInternals tools http://technet.microsoft.com/en-us/sysi ... s/bb897553. I've not tried it but it looks useful. Of course the ability to do this kind of thing is going to rely on rights that your network admin might be a little wary of allowing.
asutcliffe
- Version: 9.4.1 - 10.1
If you just want to start or stop the service remotely, you can use SC. This can be particular useful when TM1 has consumed all available RAM meaning logging on via remote desktop is incredibly slow.
http://ss64.com/nt/sc.html
You need to run it as an account with sufficient rights to stop the service on the target server though.
Another thing I've tried in the past is to create a script on the server to recycle the service and then call this from a TI process.This enables you to give people the ability to restart the service without giving them any extra access to the server itself. I haven't used it often but seems to work OK when I've tried it.
I hope that helps.
edit: all this assumes your server is running windows of course.
I hope that helps.
For shutting down or restarting a service with net stop and net start commands I use the MS ps tools utility linked to by Duncan which allows you to remotely execute a batch script on another machine. But should you need to do more than shut down a service remotely and reboot a server itself then it's even simpler, I have always used this very simple batch script.
(restarts remote server with time delay of 3 seconds. Very handy if server has become "locked up" and isn't accepting rdp connections.)
shutdown /r /f /m \\<your physical server name here> /t 003-
mincharug.shulft
i want it to stop the TM1 server from services which is running under server (2003 server) from my local PC .
please tell me what script can write to this?
asutcliffe
As I've suggested, one way to achieve this would be:mincharug.shulft wrote:i want it to stop the TM1 server from services which is running under server (2003 server) from my local PC .
sc \\server_name stop service_name
