Backus–Naur Form for TM1 Syntax
John Hammond
- OLAP Product: PAW/PAX 2.0.72 Perspectives
- Version: TM1 Server 11.8.003
- Excel Version: 365 and 2016
Just wondered if there is TM1 Syntax in Backus–Naur Form or equivalent out there.
If not I might have a go myself when Caprice goes on one of her girlie nights out and I have nothing to do of an evening...
- stephen waters
- Version: 10_2_2
- Excel Version: Excel 2010
Re: Backus–Naur Form for TM1 Syntax
John, are you posting in the right sort of forum??John Hammond wrote:If not I might have a go myself when Caprice goes on one of her girlie nights out and I have nothing to do of an evening...
- jim wood
- Version: PA 2.0.7
I guess the nearest would be variables within TI?
- Martin Ryan
- Version: 10.1
I'd never heard of it till now. After a bit of Wikipedia I think I grasp it and now the question that comes to mind is why? The documentation gives you all of this information, though obviously not as formally.
I'm just curious as it seems (to me) that watching an episode of Geordie Shore would be an equally productive use of your evening.
Jodi Ryan Family Lawyer
Somewhat off topic but the knowledge that such a creation is actually known to people outside of the UK makes me ashamed to be English and I need to go rethink my whole existence.Martin Ryan wrote: I'm just curious as it seems (to me) that watching an episode of Geordie Shore would be an equally productive use of your evening.
rmackenzie
Are you talking about rules or TI? If you mean rules, then there are quite a few online resources for E(xtended)BNF grammars for Excel formulae - TM1 rules syntax is kind of similar to this but ... the way the left hand side works is outside of this and also right-hand side multi-dimensional references obviously don't play well in the Excel context. I've also seen some interesting efforts at Excel-formula parsing engines that don't rely at all on BNF.John Hammond wrote:Just wondered if there is TM1 Syntax in Backus–Naur Form or equivalent out there.
If you're talking about TI then there's probably a lot more information about BASIC-like languages, however the problem here is that a full BNF grammar would really have to take account of the implied loops of the Metadata and Data tabs.
Robin Mackenzie
Duncan P
- Version: 9.5.2 10.1 10.2
- Excel Version: 2003 2007
I think I disagree.
The slightly difficult thing about both rules and TI (if you are intending to use the grammar for real work) is the interaction of newlines and comments with the rest of the rule or TI program.
The first thing is that newlines can appear anywhere, and indeed when they are put in to break up long lines by TM1 they often break a word - with no ill effect. However they are not completely insignificant. A #, if and only if it is the first non-blank character of a line, marks all the text till the end of the line as a comment. The combination of these things gives the following oddity.
will fill the cube with the number 30. The number of characters from each line that contribute to the string is 3 ("one"), 3 (3 spaces), 18 (all of the line) and 6 (3 spaces and the "two").
All of this means that you have to strip comments and newlines before you can even think about splitting the rule up into tokens and working out what the quoted strings are. Only when you have done that can you get down to using the grammar to parse the rule.
A grammar for TI wouldn't have to take into account the implicit looping on the middle tabs. The grammar just defines what is a properly formed program and not about what that program does in execution.rmackenzie wrote:... however the problem here is that a full BNF grammar would really have to take account of the implied loops of the Metadata and Data tabs.
[] = LONG( 'one
# a comment
2 # not a comment
two' );
John Hammond
Made a start last night
But then Geordie Shore came on...
<square-bkt-open> ::= ‘[‘
<square-bkt-close> ::= ‘]‘
<dimension-element-list> ::= ‘{‘ < single-dimension-element > [,<single-dimension-element >]... ‘}’
<complex-dimension-element-list> ::= < single-dimension-element > | <dimension-element-list>
<lhs-area> ::= <square-bkt-open><complex-dimension-element-list> [‘,’<complex-dimension-element-list>]… <square-bkt-close>
<rhs-area> ::= <square-bkt-open> <single-dimension-element> [‘,’<complex-dimension-element-list>]… <square-bkt-close>
<db-statement> ::= ‘DB(’ <alpha-expression> ‘,’ <alpha-expression> ‘,’ <alpha-expression> [‘,’ <alpha-expression> ]… ‘)’
rmackenzie
I think you're right and I'd got ahead of myself thinking about what the grammar would be practically useful for. Chomsky nicely sums up this issue you're raising.Duncan P wrote:I think I disagree.A grammar for TI wouldn't have to take into account the implicit looping on the middle tabs. The grammar just defines what is a properly formed program and not about what that program does in execution.rmackenzie wrote:... however the problem here is that a full BNF grammar would really have to take account of the implied loops of the Metadata and Data tabs.
Robin Mackenzie
ParisHilton
- OLAP Product: Tm1
- Version: 9.5
- Excel Version: 2007 2010
I would suspect, that if you have a BN or something similar, then it would be very possible to write a decent rules editor.Martin Ryan wrote:I'd never heard of it till now. After a bit of Wikipedia I think I grasp it and now the question that comes to mind is why?
I keep starting this project myself, but it's a whole big can of worms !
“The way I see it, you should live everyday like its your birthday”
TM1 9.5 Cognos BI 8.4 Excel 2007. 128GB Ram. E7450@2.40Ghz -24 core. Fluffy white dog.
