Work sheet does not contain Range Slice
srilakshmi
OLAP Product: i don t know
Version: 9.5.2
Post by srilakshmi »
Am trying to retrieve details on IT spend with the help of TM1. I first create the work sheet with the IN-spreadsheet browser and make the necessary changes i need, then when i refresh i get a prompt saying "Work sheet does not contain Range Slice". What is this Range Slice? What should i do when i come across this. Please help. Thanks
jim wood
Version: PA 2.0.7
Re: Work sheet does not contain Range Slice
Post by jim wood »
The first thing I wonder is why you are using the in-spreadsheet browser to start with. Wouldn't you better with an active form?
