I currently populate a subset with the elements (dates) that exist on the source file. The subset is used in a view and the view is used to identify cube records where the measure must be zeroed out before loading the new volume.
Date Product Volume
1/1/2011 A 888
1/1/2011 A 44
1/1/2011 B 21
1/2/2011 B 3
1/2/2011 C 10
In the MetaData Tab I delete all of the elements in the Subset
DimPeriod = 'VodDay';
subRef = 'zzTiVODPriceDates';
sOrderDay = TRIM(v_order_day);
#^^^ Delete All of The Elements From The zzTiVODPriceDates Subset In the VodDay Dimension
SubsetDeleteAllElements(DimPeriod, subRef);
In the Data Tab I populate the element in the SubSet
#^^^ Create the subset dynamically in VodDates Dimension
#^^^ Update the zzTiVODPriceDates Subset in the VodDay Dimension with the date values from the File.
SUBSETELEMENTINSERT (dimPeriod, subRef, sOrderDay, 1);
This works; however, there are duplicate values in teh subset. Using the sample data provided above, there will be 5 records in the subset (3 for 1/1/2011 and 2 for 1/2/2011). The file I loaded recently has 150,000 records for the January activity.
How can I only add unique elements to the subset?
Walt
Adding Unique elements to a subset
Re: Adding Unique elements to a subset
Hi Walt,
if your dates are ordered you could do the following:
in Prolog add:
# memorizes previous date, initialization only here
sOrderDayPrev = '';
in Metadata tab no change.
in Data tab add:
IF(sOrderDay @<> sOrderDayPrev);
sOrderDayPrev = sOrderDay;
ENDIF;
HTH,
Marcus
in Prolog add:
sOrderDayPrev = '';
in Data tab add:
ENDIF;
HTH,
Marcus
Thank You Marcus.
Easiest way to create a subset with unique elements is to insert into a temporary dimension on the metadata then on the epilog loop through the temp dimension and build the subset.
- OLAP Product: TM1 & Cognos DMR, Palo
- Version: 9.5.1
...does somebody also know a rule how to count the leaf elements on a (unique) subset or dimension like this? Moreover like a count(distinct <leafelements>) on the dimensions leafs?
Stefan
Stefan
How do you want the output? Do you want to retrieve the number for use in a TI process? For use in a rule? Just for personal intrigue?
... same general principle could be used but with a DimSiz function at the end instead.lotsaram wrote:Easiest way to create a subset with unique elements is to insert into a temporary dimension on the metadata then on the epilog loop through the temp dimension and build the subset.
Rules are written against cubes, not dimensions, so there is no COUNT function in rules. You could get a count of the number of elements in a hierarchy point, which could theoretically represent the whole dimension or a subset of the dimension, by placing a value of 1 in every leaf cell. You could also post the size of a dimension to a cell via a rule like:ETHSSN wrote:...does somebody also know a rule how to count the leaf elements on a (unique) subset or dimension like this? Moreover like a count(distinct <leafelements>) on the dimensions leafs?
['Size']=DIMSIZ('Dim');
