ClassFactory error in Excel
ps_in_atl
Version: 10.1.1 x64_MS Server 2008
Excel Version: Excel 2007
Post by ps_in_atl »
I have a user who just installed 9.5.1 and is getting the following error upon opening Excel (2007): "System Error &H80040111 (-2147221231). ClassFactory cannot supply requested class". It must be related to the add-in, but no idea why.
Any help?
thec0dy
OLAP Product: Cognos Perspectives
Version: 9.5.1
Re: ClassFactory error in Excel
Post by thec0dy »
Did you ever figure out the fix to this? I am having the same issue.
jim wood
Version: PA 2.0.7
Post by jim wood »
Have you tried the good old fall back in these situations.... re-install both (or just TM1) excel and TM1?
ccierpik
Post by ccierpik »
I wanted to check and see if anyone has come up with a solution for this. Everything was working fine and when working with an embedded excel file in powerpoint (no TM1 references, but I did have another workbook open with TM1) it crashed and from that point on I get the reference error message. I've uninstalled office and tm1, deleted *.exd files and nothing seems to work. I'm using Excel 2007 and TM1 9.5.1. Thanks for your help.
ParisHilton
OLAP Product: Tm1
Version: 9.5
Excel Version: 2007 2010
Post by ParisHilton »
Hi , what version of windows are you using?
We've had a recent problem where a windows 7 update has caused nasties.
P
xx
“The way I see it, you should live everyday like its your birthday”
TM1 9.5 Cognos BI 8.4 Excel 2007. 128GB Ram. E7450@2.40Ghz -24 core. Fluffy white dog.
ccierpik
Post by ccierpik »
It's Vista. I finally got it to work after reinstalling Excel and TM1 and then copying in MSComCtl.ocx. I had tried that before, but I guess I just needed to do a clean install first.
