As we are moving from Tm1 ver 9.5.1 to 9.5.2- Would like to know Configuration Settings for TM1 9.5.2.
Please advise.
Ravi
Upgrade from 9.5.1 to 9.5.2
- Version: TM1 11 and up
Re: Upgrade from 9.5.1 to 9.5.2
You mean apart from what's in the documentation? Please can you be a bit more specific about what you need to know, as this will make it easier to answer your question.
Paul
- OLAP Product: cognos
- Version: tm1 9.5
Hi Paul,
Thanks for reply.
We are currently on 951 ver.
I need to compile a list of Configuration Settings for TM1 9.5.2 And compares against 9.5.1
Please advise and also provide me link for documentation on this.
Ravi
Thanks for reply.
Ravi
The release notes should be all that you need here! Have you read them? Have you done a search of this forum? (as there are many topics discussing 9.5.2, why add a new one?) The major significant difference is the ParallelInteraction configuration parameter. Had you read the documentation or done a quick search and read of topics discussing 9.5.2 then you should know this.ravi wrote:Hi Paul,
Thanks for reply.
Ravi
- Version: tm1 9.5
Hi lotsaram,
I am still searching such documents- I am currently looking in the link
http://publib.boulder.ibm.com/infocente ... onfig.html
Could you please advise- if there are any document need to be looked so that compare the diffrence between 951 and 952 configuration.
Thank you
Ravi
Thank you
Ravi
I went to Google and typed in "release notes for 9.5.2". Amazing, huh?
