TM1 9.5.2 Cube Viewer Performance Issue
PlanningDev
Version: 2.0.5
Post by PlanningDev »
Has anyone noticed that the cube viewer in TM1 Perspectives performs much slower in 9.5.2 than in previous versions (Specifically 9.5.1)?
leighton harker
Version: 9.5.2
Excel Version: Excel 2003
Re: TM1 9.5.2 Cube Viewer Performance Issue
Post by leighton harker »
We have just completed the upgrade from 9.5.1 to 9.5.2 and I would say that performance of cube viewer via perspectives was marginally faster if anything. However, it wouldn't be a fair comparision as part of the upgrade we also upgraded the server OS and doubled the RAM
turbob
Version: 9.5.1 + 9.5.2
Post by turbob »
I have seen the problem of slower view loading (which is normally the same as opening view in Cube Viewer) in my nightly server starting routine. Even with a faster CPU (2.4 GHz istead of 2.0 GHz) and more Memory (96 GB instead of 10 GB) in the new server with 9.5.2 installed, the ViewConstruct in TI via Chore is seven Times slower than in the old server. The loading of the cubes and the calculation of the persistent feeders ist 20 % faster, which is logical because of the higher CPU clocking.
Has anyone the same problem or solutions to this?
Greets
Thomas
