Contributor TI scripts overwriting security (URGENT!)
sjokesson
Post by sjokesson »
When users perform certain actions, "submit" being one of them", the value at the intersection of }Clients and }Groups in }ClientGroups is deleted. For the user, this means that the organization he/she was just editing is no longer visible as an option in the main Contributor screen. I'm still investigating to determine the full set of circumstances that trigger this overwrite.
I should add that I've manually configured Contributor security in }ClientGroups and also in }CellSecurity_}tp_application_permission}{[tp_application code]} due to problems with Contributor's "manage rights" utility. The problem with overwriting described above impacts only the }ClientGroups cube.
THANK YOU for any suggestions you can provide!!!
sjokesson
Re: Contributor TI scripts overwriting security (URGENT!)
Post by sjokesson »
I just have to vent a bit as an addendum to the prior post. Why on earth would a vanilla implementation of TM1 Contributor include functionality which overwrites settings in }ClientsGroups?
I can understand the overwriting to }CellSecurity_}tp_application_permission}{[tp_application code]}, and can even find code to do that in various TI scripts. But messing with }ClientGroups totally shuts users out.
