Came accross this today when trying to use dimensional qualification (i.e. 'dim':'account'') inside a multiple-element group (i.e {'elmnt1,'elmnt2', 'etc'} ) on the left side of a rule.
This will error when saving with "Element Not Found":
[ { 'Account':'Sales' } ] = n: 1000;
This will error when saving with "Missing Right Brace":
[ { 'Units', 'Account':'Sales'} ] = n: 1000;
Either should work. 9.5.2 FP1 on AIX.
-- John
Disambiguation in Multiple-Element Rule Not Possible
rmackenzie
Re: Disambigation in Multiple-Element Rule Not Possible
You are using the wrong syntax.
The correct syntax would be:
Actually you don't need the { and } for a single element. The other statement should be:
Once again, you don't need the { or }.
This should work fine:
Etc etc.
Mods - this shouldn't be in the bug sub-forum.
[ 'Account':{'Sales' } ] = n: 1000;Code: Select all
[ 'Units', 'Account':{'Sales'} ] = n: 1000;This should work fine:
['dim1':{'elem1','elem2'},'dim2':{'elemA','elemB'}]=N:100;Mods - this shouldn't be in the bug sub-forum.
Robin Mackenzie
image2x
- OLAP Product: TM1, PAX, PAW, SPSS
- Version: 2.0.916.10 on RHEL
Ahh-hah.... I don't recall that one being in the documentation (though I haven't read it since 9.4).rmackenzie wrote:Your using the wrong syntax. The correct syntax would be:
Yes, please move. Thanks.rmackenzie wrote:Mods - this shouldn't be in the bug sub-forum.
rmackenzie
Re: Disambiguation in Multiple-Element Rule Not Possible
Wouldn't be the first timeimage2x wrote:I don't recall that one being in the documentation
Robin Mackenzie
