I am trying to export the data from a view through TI using an ASCII function.
Data Tab
DatasourceASCIIDelimiter=';';
TextOutput('xyz.txt',v1,v2,v3,v4,v5,v6,value);
when I use the above script the data is exported in the below format
"GO Americas";"Golf Shop";"Golf Accessories";"Jan";"Budget Version 1";"Quantity";"853."
Can you please tell me which function should I use to eliminate the "" from the all the above strings. The output should look like
GO Americas;Golf Shop;Golf Accessories;Jan;Budget Version 1;Quantity;853.
Radhika
ASCII Output
- Michel Zijlema
- OLAP Product: TM1, PALO
Re: ASCII Output
Hi Radhika,Radhika wrote:Can you please tell me which function should I use to eliminate the "" from the all the above strings.
You can use DatasourceASCIIQuoteCharacter = ''; for this.
Michel
Radhika
- Version: v9.4.1
- Excel Version: Microsoft Excel 2003
Re: ASCII Output
Thank you for your quick response Michel.
