Error handling.
ryan
OLAP Product: COGNOS
Version: 9.0
Error handling.
Post by ryan »
Is there any way or functions available for error handling in TM1's TI process?
If errcode = 3604 then
else
endif;
Thanks in advance.
Configuration Details
Microsoft Window Server 2003 Exterprise x64 Edition Service Pack 2
RAM 32 GB
using IBM Cognos Express Xcelerator (Version 10.1)
MS-Office Excel 2010 (12.0.6514.5000)SP2 MSO (12.0.6425.1000)
Microsoft .NET Framework 3.5
Re: Error handling.
ryan wrote:Is there any way or functions available for error handling in TM1's TI process?
else
endif;
Thanks in advance.
You wish. As, indeed, do most of us.
The closest you can get to that is to write some code to ensure that you check your variables for valid input. (Non-empty, beyond a certain length, translates to a non-zero numeric value, or what have you.) If you find something invalid, use a standard If block to handle the exception. (Do an ItemSkip or ItemReject, write to a log file, use a default or whatever.) Otherwise the only "error handling" that you have is what TI will do for you, which is up to and including tossing out the row as a result of (say) a key error.
