Appreciate if you could give me some feedback on wether TM1 can be deployed using XenApp. XenApp I understand is enables any Windows® application to be virtualized.
Will this impact performance ? Any documentation or any link on this would be of great help.
XenApp - TM1
image2x
- OLAP Product: TM1, PAX, PAW, SPSS
- Version: 2.0.916.10 on RHEL
Re: XenApp - TM1
<bump>
Same question. Anyone doing this?
- Cam
- Version: 9.5.1
- Excel Version: 2003
Re: XenApp - TM1
We use citrix server, connecting tm1 perspectives via publishing the Excel add-in, and in four months it has worked well and fast for users in other countries. Connecting plain Perspectives to other countries had slow time responses and users get a bit desperate. We have a local file server which is near, in other to let them save xls by mapping drives between both citrix and the local file server.
PlanningDev
- Version: 2.0.5
Re: XenApp - TM1
I second this. We do the same. The only issue here is that slicing a view out of the web will be a little more painful unless you develop a way to open a browser through citrix that will slice to a excel on the citrix server. Otherwise you have to slice then save then reopen in citrix.Cam wrote:We use citrix server, connecting tm1 perspectives via publishing the Excel add-in, and in four months it has worked well and fast for users in other countries. Connecting plain Perspectives to other countries had slow time responses and users get a bit desperate. We have a local file server which is near, in other to let them save xls by mapping drives between both citrix and the local file server.
