Insert Element Using TI Process Parameters failed
Legemza
Version: 9.5.1
Post by Legemza »
i'm trying to add from websheet into the cube some elements using TI process with parameters. The process fails only when is running from the websheet.
I tried to find, what is sent from web and therefore i used the AsciiOutput function. In the file were " ". Why is sending websheet into process only empty space instead of string? When i tried an older excell sheet, the process was running correctly and i have obtained from web strings that i have expected. Can someone help me to find where is the problem? Is it in wrong excel version or what?
Lado
