That doesn't surprise me.Martin Ryan wrote:That trend is set to continue. IBM mentioned at the 9.5.2 launch that there will not be a service pack for 9.5.1. There'll be a service pack for 9.5.2 scheduled for the end of the year. Presumably there'll be a fair few hot fixes between now and then.Alan Kirk wrote:But prior to that, when was the last:
- Bug fix;
- Patch;
- Service pack
{Looks at the list of changes to 9.5.2, which appears to be rather more than a decimal point relase, he says with profound understatement.}
{Looks at 9.5.1.}
{Looks back at 9.5.2, considers how much testing would need to be done for models which were designed for and optimised for 9.5.1}
Yup, "just upgrade" is going to be heaps of fun for those affected.
When it comes to IBM support for any version earlier than the current one and maybe the one before that (although if you're correct about this, you can even scratch that proviso out), I'm reminded of the words of Judge Kent in the case of Bradshaw v. Unity Marine Corporation.
"Upgrade to the current version" is not, to my mind, support in any reasonable definition of the term.Judge Kent wrote:But at the end of the day, even if you put a calico dress on it and call it Florence, a pig is still a pig.
