Can tm1 web display the alias for the name of dimension?
RabbitSlava
OLAP Product: IBM Cognos TM1
Version: 9.5.
Post by RabbitSlava »
Hello.
I have the TM1 cube.
The cube has 2 dimensions: P01_time, P01_products
Dimensions have a technical name.
In the title of dimensions I use the prefix P01_.
TM1Web shows two names for the dimensions: dimension name and the subset name
It is necessary that TM1 does not show the name of the dimensions
Re: Can tm1 web display the alias for the name of dimension?
RabbitSlava wrote:Can tm1 web display the alias for the name of dimension?
Aliases are designed for dimension elements, not the dimensions themselves. Although you can add an alias to a dimension name by adding an alias attribute to the }Dimensons dimension, there is no facility in TM1 to tell the web to display this instead of the actual dimension name in the user interface.
There is a new alias introduced in TM1 9.5 for control objects which from memory is called }TM1DefaultDisplayValue. The intention is to convert the long winded and sometimes seemingly random assortment of characters that you get as the native element name in the }Clients dimension and convert it into something intelligible for display in Contributor and other UIs.
It's a long shot but it might work for other control dimensions (but no guarantee I think the odds are <50%) and I have no way of testing this at the moment.
RabbitSlava
Version: 9.5.
I checked the work alias} TM1DefaultDisplayValue.
Does not work: (
