TI-Job - access to db connection info
SBrenner
OLAP Product: IBM Cognos TM1
Version: 9.5.0
Post by SBrenner »
I use a TI process to load data from a RDBMS into a cube. I specified the database in the TI-tab 'Datasource' (the entered data are 'name of data source', 'user', passwort' and the SQL).
Is it possible to use these data in my code? Because I have to write back log infos to the same database. I know I can open a new DB connection with "ODBCOpen", but to avoid errors I want to use the same data for username and passwort.
Are there any variables which hold the entered DB data?
Thx in advance.
Steve B.
SBrenner
Version: 9.5.0
Re: TI-Job - access to db connection info
Post by SBrenner »
I found it. The data are stored in the internal Turbo Integrator variables.
They are (in 9.4.x):
  • DatasourceNameForServer
    DatasourceASCIIDecimalSeparator
    DatasourceNameForClient
    DatasourceASCIIThousandSeparator
    DataSourceODBOCatalog
    DatasourceType
    DatasourceASCIIQuoteCharacter
    DataSourceODBOConnectionString
    DatasourceUsername
    DataSourceODBOCubeName
    DatasourcePassword
    DataSourceODBOHierarchyName
    DatasourceCubeview
    DataSourceODBOProvider
    DatasourceDimensionSubset
    DataSourceODBOSAPClientID
    DatasourceASCIIDelimiter
    DataSourceODBOSAPClientLanguage
