Longtime lurker in here, nice to meet you
As the subject states, I'm having troubles with opening excel files via TM1WEB. We're running an x64 server setup. I've tried about everything I could find on the forums, but with limited success.
This includes clearing the cache, registering the ocx and dll, setting the IIS instance (we're on IIS6) to 32 bit, registering the correct ASP.NET version, ..
The error we get to see is the well known 'cannot convert MS Excel workbook to XML".
Apparently, the system does work, when I shut down the tm1excelservice service, start it manually using the -standalone parameter then restart the service using the services.msc console.
So my question is: has anyone ever had and solved the same problem? Does anyone know what the -standalone parameter does, in contrary to running the service as a service?
Thanks for your time
Joris
