Hi everybody,
i Have problem with inserting dates to the cube by Tm1web websheet. I have celll with funcion DBRW(cube,dim1, dim2, dim3). Cell containing date in format dd. mm. yyyy.
When i try to edit this field on tm1web field (cell) represents excel serial number and date format in disabled. This is not acceptible for users. Do you have any idea how to workaround it?
Thx
TM1 Websheets - Insert Date
Re: TM1 Websheets - Insert Date
I see you are enterprising enough to come to this forum, regoister, and post a question. Are you not enterprising enough to use the search feature? There are numerous posts on the forum that cover this very topic. Give search a try, you'll like it.
