Can anyone tell me how to pass a varible value into a parameter so that i can insert that parameter into a column in Sql table
Issue:
Taking a Cube View as Source and it is having varibles V1,V2,V3,V4,V5 DEFINED and now i have Col1,Col2,Col3,Col4,Col5,Col6 in Target Table
I need to pass V3 | V4 |V5 |'Rate' (Concatinated) into Col 6
In Prolog i used
scol6input = V3|V4|V5|-|'Rate' ;
In Data Tab:
In Sql Statement :
I used scol6input Then its not trowing any error but the Col6 in Target table is having just "- Rate"
My 3 variables are not showing in the target????
How do i get it
Thanks for your time
How to Concatinate the Variables ??
- vinnusea
- Version: 10.2
Vinnusea
Vinnusea
ajain86
- Version: 9.4.1 9.5 9.5.1
- Excel Version: 2003 2007
Re: How to Concatinate the Variables ??
the prolog tab does not read in the datasource.
move this statement to the data tab:
Ankur Jain
- vinnusea
- Version: 10.2
Yes
Now Its Working good after moving to Data tab..
Thank you soo much
Thank you soo much
Vinnusea
Vinnusea
