we have the following challenge in our company model:
One measure KG need to be calculated by using different rules.
The activation of rules is leading by dimension elements.
Our challenge in rules:
Element FS + AREA#1 till AREA#4
['KG DAY',{'FS'}, {'AREA#1','AREA#2','AREA#3','AREA#4'}] = N:ROUNDP(if (['DAY % (REG)'] + ['CTR % (REG)'] = 0,
if (['DAY % (QAD)'] + ['CTR % (QAD)'] = 0,0,['DAY % (QAD)']),['DAY % (REG)']) * ['KG (DEM)'],0);
Element FS + AREA#5 till AREA#10
['KG DAY',{'FS'}, {'AREA#5','AREA#6','AREA#7','AREA#8','AREA#9','AREA#10'}] = N:ROUNDP(if (['DAY % (CUS)'] + ['CTR % (CUS)'] = 0,
if (['DAY % (REG)'] + ['CTR % (REG)'] = 0,0,['DAY % (REG)']),['DAY % (CUS)']) * ['KG (DEM)'],0);
The AREA elements are part of a dimension hierarchy and is not de lowest level. The total hierarchy consist out of 5 levels and Area is the 4th level.
Our calculation needs to work up to lowest level (level 0).
With the rules we don't get the right results. Results are only shown up to Area level.
Can someone give use advise?
Barbara
Different rules need to be taken in account for 1 measure
- Michel Zijlema
- OLAP Product: TM1, PALO
Re: Different rules need to be taken in account for 1 measur
Hi Barbara,
Probably the easiest way to do this is to add an attibute to the dimension containing the AREA# elements, defining the calculation method on the lowest level and then use a rule that checks this attribute, f.i.:
['KG DAY','FS'] = N:
IF(AttrS('areadim',!areadim, 'CalcMethod') @= 'type1',
ROUNDP(if (['DAY % (REG)'] + ['CTR % (REG)'] = 0, if (['DAY % (QAD)'] + ['CTR % (QAD)'] = 0,0,['DAY % (QAD)']),['DAY % (REG)']) * ['KG (DEM)'],0),
ROUNDP(if (['DAY % (CUS)'] + ['CTR % (CUS)'] = 0, if (['DAY % (REG)'] + ['CTR % (REG)'] = 0,0,['DAY % (REG)']),['DAY % (CUS)']) * ['KG (DEM)'],0));
Michel
Michel
kpk
- OLAP Product: TM1, CX
- Version: TM1 7x 8x 9x 10x CX 9.5 10.1
- Excel Version: XP 2003 2007 2010
You can split the calculation on the other side of the rule with a conditional statement.
I mean you can define an attribute (probably a A/B flag enough in your case) for each AREA elements and use that flag to define the required calculation.
You can use the ELPAR() function instead of the ATTRS() if you are sure that there is only one parent for each element or the order of the parents are fixed and will be not changed.
['KG DAY',{'FS'}] = N:
IF(ATTRS('AREA',!AREA,'TYPE')@='A',
Best Regards,
Peter
Peter
bmeer31
- Version: 9.5
- Excel Version: 2003
Thanks for your replies!
Barbara
Barbara
