Error in rule
daya007
Version: 9.5.1
Error in rule
Post by daya007 »
I have a measure in which one element is string(Current status) which contains a single alphabet('G', 'R', 'Y') and i have a simple element(Status). I want to populate the numeric field such as if string element has 'G' then 1, 'Y' then 2 and 'R' then 3.
I wrote a rule like this.
['Status']=IF(['Current Status']='G', 1, IF(['Current Status']='Y', 2, IF(['Current Status']='R', 3, 0)));
Am am getting following error
TM1 Error
Line 1: Syntax error on or before:
incorrect logical comparison
Please help me with this error.
Daya
Re: Error in rule
daya007 wrote:Hi,
TM1 Error
Daya
Use @=, not =, to do a comparison against a string value.
daya007
Version: 9.5.1
Re: Error in rule
Post by daya007 »
Hi Alan
Thanks for the quick reply
I have tried
['Status']=IF(['Current Status']@='G', 1, IF(['Current Status']@='Y', 2, IF(['Current Status']@='R', 3, 0)));
still am getting following error.
Donno where i am missing.
TM1 Error
logical expression
Rule could not be attached to the cube, but changes were saved.
OK
tryinghard
Version: 9.5.1
Re: Error in rule
Post by tryinghard »
one thing to add that @and = should be together i.e. no space between them.
daya007
Version: 9.5.1
Re: Error in rule
Post by daya007 »
Yes they are together but same error :(
Re: Error in rule
Post by David Usherwood »
You're referencing string content using the [...] syntax, which won't work. Write full DB() references instead.
daya007
Version: 9.5.1
Re: Error in rule
Post by daya007 »
Thank you so much
it worked :D
