I want to know how the complex templates are created in TM1? What all are the features involved other than simple slicing?What all can be included in a template?
I request you to kindly provide me with the sufficient information required please.
Template Creation
- Version: 9.4
Re: Template Creation
The simple answer is "anything that you can include in a standard Excel file". The longer answer is:Prathiksha87 wrote:I want to know how the complex templates are created in TM1? What all are the features involved other than simple slicing?What all can be included in a template?
http://forums.olapforums.com/viewtopic.php?f=3&t=1037
And before posting in the Bugs forum, which this post was moved from since it doesn't relate to a bug:* Try to make the question as specific as possible. A general question like "How do I write a rule?" is difficult to answer without copying out the whole of the user manual.
http://forums.olapforums.com/viewtopic.php?f=18&t=251
- Version: 9.4
Tell me how to create templates from cubes in Cognos TM1? I know that by using Active Forms or slicing we can do it but when comes to complex cubes with more than one or two views what should be done and how to proceed after slicing?Is it possible to get values from more than one cube in a single worksheet?How to include an action button in a template?
Request you to kindly give me a clear idea on template creation and the possible steps involved under this.
- Version: 9.4
Hi Alan,
I'm a fresher in TM1 and it will be of great help from your side if you can atleast provide me with a link which will give me the necessary details regarding my query.
Thanks & Regards.
Prathiksha.
Thanks & Regards.
Prathiksha.
- OLAP Product: IBM Planning Analytics
- Version: Latest version
- Excel Version: 2003 to 2019
Suggest you read the TM1 User Guide and Reference Guide to have an idea how to use Excel-TM1 formula. This will help you a lot. I doubt anyone here will provide comment to your request given the nature of your question.
- OLAP Product: IBM COGNOS TM1
- Version: 9.5
for creating the action button,you can get this when you run your TM1 perspective,select insert action button , you can view a button on excel sheet,select on that change the name and properties.
Action Button is used for running the TI process, and also to load data.
- Version: 9.4
Hi Harry,
Thanks a lot for your suggestion. I'll surely go through it.
Hi Viswaraj,
Thanks a lot for the information given.
It is very useful.
Regards.
Hi Viswaraj,
It is very useful.
Regards.
