hi,
in turbo process in variables tab i inserted a variable which tooks only three values which is supposed to be hard coded.How can i give that in formula?
My variable takes only three values h1,h2,h3
i wrote like v1='H1'||'H2'||'H3';
but not working
Can anyone tell me how to do that??
If I am not wrong then the dim_house and dim_number are related to each other. First one has got the house and the other dim has got the house numbers. If this is the case then you have to re-think how you are modeling your cube.????
Secondly if the h1, h2...values are already in your data source then why you want to hardcode the value????
The process you are writing, is that to create dimension or to load data in the cube???
You need to tell us more about the requirements...attach a sample data and process which you are working on.
I think you're trying to say that the user must choose one of three values, and if they don't, then you want to reject it? If that's what you mean, here's a way
Please do not send technical questions via private message or email. Post them in the forum where you'll probably get a faster reply, and everyone can benefit from the answers. Jodi Ryan Family Lawyer
