I'm trying to write a rule,using two external (lookup) cubes to calculate the amount, please help me how to write the feeders for the following rule.
['amount']=N:DB('inve_Vol',!d_month,!d_year,!d_version,!inv_type,!inv_ca,'quantity') * DB('inv_rates',!d_month,!d_year,!d_version,'Unit Price');
when i try to trace the calculation and feeders in tm1 view the values are not fed and calculated.
regards,
Sunitha
write feeders in rules using DB function
- kielmc
- Version: 10.2.2 FP4
- Excel Version: 2013
Re: write feeders in rules using DB function
Since this is simple multiplication, you can feed from either factor, using 'quantity' in the 'inve_Vol' cube or 'Unit Price' in the 'inv_rates' cube.['amount']=N:DB('inve_Vol',!d_month,!d_year,!d_version,!inv_type,!inv_ca,'quantity') * DB('inv_rates',!d_month,!d_year,!d_version,'Unit Price');
something like this:
#feeder in 'inv_Vol' cube
['quantity'] => DB('rule cube', dim1, dim2, ..., 'amount');
or
#feeder in 'inv_rates' cube
['Unit Price'] => DB('rule cube', dim1, dim2, ..., 'amount');
Andy Key
- Version: 2.5 to PA
- Excel Version: Lots
...but as Quantity is more sparse than Price, use the feeder from the cube with Quantity to avoid overfeeding.
Andy Key
