regarding paramterised query in tm1
angel1234
OLAP Product: tm1 cognos
Version: 9.5
Post by angel1234 »
hi,
i have created a parametrised query in ti process which is connecting to oracle .
i defined a parameter called year_num in TI.my query is
select
t1.account_category as account_category,
from
t1
where
t1.fiscal_year_number = @Year_num;
but the query is not working it shows a failure status in ti while i am clicking preview
thanks and regards
anjali.
angel1234
Version: 9.5
Re: regarding paramterised query in tm1
Post by angel1234 »
the query is working fine with the hard coded value for year_number=2010.but i have to implement it with a variable
which dynamically accepts the year
Michel Zijlema
OLAP Product: TM1, PALO
Version: both 2.5 and higher
Excel Version: 2003-2007-2010
Post by Michel Zijlema »
Hi Anjali,
The right notation for using a TI parameter in the query text is either ?year_num? of '?year_num?', depending on data type.
Michel
angel1234
Version: 9.5
Post by angel1234 »
hi,
when i am using the following query
select
from
t1
where
t1.fiscal_year_number = ?Year_num?;
i am getting query failed error in tm1 while cilcking the preview .Can any suggest a solution for this?
thanks and regards,
angel
angel1234 wrote:hi,
select
from
t1
where
thanks and regards,
angel
The query that's used to drive the the preview will use the default parameter(s) that you've specified in the Parameters tab.
Make sure that you have a valid default specified for the Year_Num parameter.
In fact, also make sure that you have specified Year_Num as a parameter in that tab, and haven't just used it in the query without having done so.
angel1234
Version: 9.5
Post by angel1234 »
hi,
still its not working :(
query is :
select * from table1 where field1=?P0?;
in advanced tab-->parameter tab
i have given parameter as P0
type as numeric
default value 1.0000
prompt question as P0
Kindly let me know any thing i have missed out
regards
Angel
angel1234 wrote:hi,
query is :
type as numeric
What's the exact data type of field1 in the database?
MarioRubbo
Version: 9.5
Post by MarioRubbo »
angel1234:
I have only been able to get this to work for me by treating everything as string. I had a similar circumstance and I had to cast my Year column as a string and then compare that to my parameter in TM1 which I defined as a string.
e.g.
where str(year_num,4) = '?year_num?'
angel1234
Version: 9.5
Post by angel1234 »
hi,
i am using ms acess db.The datatype for the column field1 is 'number'.
i modified the query like
select * from table1 where str(Field1,1)='?P0?' (still sql is getting failed)....
now i changed the default value to 1
and type of P0 to string.
Can any one give any other suggestions ????
regards
angel.
MarioRubbo
Version: 9.5
angel1234:
The str() function is the example I sent you is specific to the Sybase database that I am using. You need to substitute it with the appropriate datatype conversation function for Access.
angel1234
Version: 9.5
Post by angel1234 »
hiiiiiiiiiiiiiii :)
got it workedddddddddd.thanks for alllllllllllllllllllllllllllllllllllllllllll
regards
angel
