Apache Tomcat installation
I am attempting to install Apache Tomcat on a Windows 2003 64bit server and the documentation is less than stellar. Has anybody done this and know how to do it?
- Version: 9.5
Re: Apache Tomcat installation
simply just click next through the end of installation and deploy the web archive
- Excel Version: 2003
If you're installin the TM1 Contributor, I think the document is clearn enough unless you have something else.
Here's the link for the PDF on the installation of Apache Tomcat for TM1 9.5 Contributor
http://www.ibm.com/developerworks/data/ ... ml?ca=drs-
- Version: 9.5
FYI I was not able to run Contributor on the Apache Tomcat version which is provided (6.0.20). Version 6.0.18 does work however. Go figure!!
http://public.dhe.ibm.com/software/dw/d ... apache.pdf
Something else that I found...I was originally working on my local server, then changed to a different server name. Contributor would not load, and I found that the server name needs to be changed in the Tomcat config file in the following directory. Only one Contributor app to a server (you can then add servers from the portal after logging in): C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\pmpsvc\WEB-INF\configuration\pmpsvc_config.xml
