Creating TI to add attributes to cubes
appleglaze28
Post by appleglaze28 »
I was thinking of creating a subset for the }Cubes dimension for non-control cubes, what syntax is there to use to like be able to use "}" as my basic determinant of control cubes...but I'm not sure how EQUAL or LIKE syntax would be for TI.
Re: Creating TI to add attributes to cubes
Hi appleglaze,
For some reason I feel like your personal TM1 tutor lately :lol:
This should do the trick to generate a subset of just your "user defined cubes."
{EXCEPT(
{TM1SUBSETALL( [}Cubes] )},
{TM1FILTERBYPATTERN( {TM1SUBSETALL( [}Cubes] )}, "}*" )}
Phil Bichard's MDX primer is a good resource!
If you want to process all members of the }Cubes dimension in TI then you can just test the first character with sub string eg.
IF( SubSt(sCube, 1, 1) @= '{' );
appleglaze28
Thanks Lotsaram, truly appreciate it...just a bit too hard to go through all the manuals not knowing if they have the stuff you need or not.
