I am using TM1 9.5 32 bit on windows XP. I try to add new client and group from TM1 Server Explorer. Then I get error dialog box: "Error with CAM Passport", even before defining the client / group name.
I have used IntegratedSecurityMode=1 which i understand that it is standard tm1 server security that i would normally use in version prior 9.5 without any problem
Andre
9.5 Error with CAM Passport when adding client / group
Herman Moller
Re: 9.5 Error with CAM Passport when adding client / group
"I have used IntegratedSecurityMode=1 which i understand that it is standard tm1 server security that i would normally use in version prior 9.5 without any problem"
For Cognos Security to work it is set in 2 areas in summary:
1) TM1p.ini which is located in your document and settings of your server(This is the setting for the Connecting Cognos 8 to read TM1). You will have some parameters that look the following:
AllowImportCAMClients = T
CognosGatewayURI =
Read your operations guide for more info
2) IntegratedSecurityMode=4 which is the Cognos Cam security. The IntegratedSecurityMode=1 will not work with Cam security as this is internal TM1 security only.
HTH
Herman
CognosGatewayURI =
HTH
Herman
ajain86
- Version: 9.4.1 9.5 9.5.1
- Excel Version: 2003 2007
New security level of TM1 9.5:
Use IntegratedSecurityMode=5 if you will be using TM1 Contributor.
Ankur Jain
