TM1 10.2 Unable to change Install Directory
Willi
Version: 9.5.2
Post by Willi »
I installed 10.2 on a Test-machine and used the Standard Install-Directory. But now I try to install on another machine and want to use a different Location. But the field where the Installation-Directory is mentioned is write-protected and the button where it seems I can browse to a different Location is greyed out. Any hint how I can activate this?
Thanks and regards
Willi
Version: 9.5.2
Re: TM1 10.2 Unable to change Install Directory
Post by Willi »
Solved. I searched the registry and found some parts of a previous Installation including the Installation-Directory. After I deleted that key I can Change the Directory during the Installation process.
hittony
Version: 10.2.2 FP6
Post by hittony »
It should be "Install Location" in HKEY_LOCAL_MACHINE -> SOFTWARE -> Cognos -> <Your previous uninstalled TM1 version> -> InstallStream
But why it was kind of locked :?:
AlastairFM
OLAP Product: TM1 / Cognos Express
Version: PAL 2.0.9.1
Post by AlastairFM »
I have just found this in Planning Analytics Local 2.0.9.1, trying to install client software separately from the server install.
Has anyone raised this as an issue to IBM ?
Changing the registry worked (thanks 'hittony') but this should not be necessary.
