I have an issue here when im opening one of the cube view with 13 dimensions on the web , i happen not to see all the dimension on the context menu,
so i want to know if there is way that i can resize the drop area so that i can see the all hidden dimensions. I'm on version 10.1.1 and viewing on IE 8.
regards
Dunky
Resizing the drop area (cuve view on the web)
- OLAP Product: TM1 in memory
- Version: 10.2
Re: Resizing the drop area (cuve view on the web)
Hello, did you found a solution for this problem?
thanks
thanks
- Version: PAL 2.0.9.18
Rihab,
Did you copy/paste a thread that is 6 years old ?
IBM Champion 2024
IBM Champion 2024
